I am more a hobby and farm welder but i would like to make a tube rack for my boat and was wondering if i could weld Aluminum 3003 alloy to Aluminum 6063 alloy and have good strength without cracking .I am goint to use a lincoln 140 with spool gun.Thanks for any advice.KenLast edited by John K.; 10-18-2015 at 10:29 PM.
Reply:5356 is your best bet. Picture sucks, here's the link: http://img.docstoccdn.com/thumb/orig/163695904.pngSent from my iPhone using TapatalkLast edited by weldeng0403; 10-18-2015 at 10:47 PM.
Reply:Originally Posted by John K.I am more a hobby and farm welder but i would like to make a tube rack for my boat and was wondering if i could weld Aluminum 3003 alloy to Aluminum 6063 alloy and have good strength without cracking .I am goint to use a lincoln 140 with spool gun.Thanks for any advice.
Reply:As mentioned I wouldn't bother with that machine. Alum is a great heat sink and requires a lot more power to weld than steel does. Mig alum is a hot process so it's poorly suited for thin alum. To mig 1/8" alum you usually need to max out a 230v 180 amp class mig using a spoolgun..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If you have never welded aluminum with a spoolgun then I would say DON'T waste your time and moneywww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by mechanic416If you have never welded aluminum with a spoolgun then I would say DON'T waste your time and money
Reply:Thanks for the help I have a 230v welder but not setup for spool gun, I will probally go with stainless.
Reply:I have that machine and a spool gun for it and welding aluminum with it is a nearly impossible feat.GravelThe difference between theory and practice is that in theory there is no difference. |
