don milligan
发表于 2021-8-31 22:26:05 | 显示全部楼层 |阅读模式
do  I need to put the impulse pump on the walbro carb. if the fuel tank is above the carb.?
Reply:Is this the carb on your gas drive welder?http://www.walbro.com/media/21936/SERVICEMANUAL.pdfRich
Reply:It has been a while since I messed with one but I can't see it working without it. No expert on the matter though.....Thanks for the link I will be an expert soon enough!Last edited by mikecwik; 10-17-2015 at 05:45 PM.
Reply:I wouldn't think that it would be a necessity. I have a fuel pump on a 10 horse Kohler, but the tank is mounted above it, though I am sure it would work fine without it, as I have had lots of 5 horse motors with no pumps that ran fine.
Reply:Originally Posted by walkerI wouldn't think that it would be a necessity. I have a fuel pump on a 10 horse Kohler, but the tank is mounted above it, though I am sure it would work fine without it, as I have had lots of 5 horse motors with no pumps that ran fine.
GMT+8, 2026-1-1 05:37 , Processed in 0.074921 second(s), 18 queries .
