Copper sheets
发表于 2021-8-31 22:26:03 | 显示全部楼层 |阅读模式
Does anybody out there have any idea how to join two pieces of copper plate together? Rivets, bolts etc. can not be used also it needs to be resistant to 1 1/2 Bar pressure and water tight. ThanksWayne H
Reply:Solder, braze, or tig weld...Rich
Reply:I believe it is in Metals And How To Weld Them from the Lincoln foundation. Some sheet doesn't lend itself to TIG welding. I haven't done it, I want a kitchen island covered with it. I'd edge it with water pipe. Solder would reduce distortion, it's a different color.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:@ WayneH - intended shape? Joint geometries? Overall dimensions of product? Finish requirements?Last edited by ManoKai; 10-21-2015 at 08:05 AM.Reason: revised question based on "water" citation by OP"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:ManoKai,The size varies, but for example take an 8x4 copper sheet then about 16 pressed copper lids (like a biscuit tin lid) 12"x8"x 3/4" deep with a 1" lip all around. This is what is needed to be fixed to the 8x4 as i said earlier each capsule  needs to be water thight and pressure tested up to 2 Bar.Regards
Reply:Sil-Phos solder. No flux required on copper, works great!
Reply:2 Bar is 29 psi, I had to look it up.  I would expect some distortion, and safety considerations apply to pressurized tanks of any kind.The simplest suggestion is Sil-Phos solder, no flux.  I would use an oxy-acetylene torch.  It is possible that an acetylene-air torch would work, and I am sure that an oxy-propane torch would work.  Sil-Phos is a brand name, but there are equivalent products from other companies.  I believe that I have heard it referred to as Phos-copper rod.   Note that the color will be silver, not copper color.  If you need color match, use oxy-acetylene with silicon bronze filler and flux.Last edited by 7A749; 10-21-2015 at 10:53 PM.Sculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:I got rid of the dupe post for you man Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Just trying to get to grips with how this site works, then i will post a sketch of what is needed.ThanksWayne
Reply:Welcome to the site from Virginia.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
GMT+8, 2026-1-1 05:37 , Processed in 0.067077 second(s), 18 queries .
