Hey Zap, my argon went bad....
发表于 2021-8-31 22:26:01 | 显示全部楼层 |阅读模式
Picked up a new tank of argon yesterday. Today I sit down to lay some practice beads and the first time I strike an arc, it blows a hole through the plate. I figured I must have forgotten to turn on the gas. double check all the gas settings, put in a freshly sharpened tungsten and try again. Same result. Turn up the gas to 20 CFH and replace the tungsten and try a third time. Same result. sparks everywhere, big hole in the plate. Scratching my head, I check the bottle again and notice that the airgas guy gave me C25 by mistake and not pure argon. Needless to say C-25 doesn't work so well with TIG. Guess I am going back to airgas on Friday.  ;-)Miller Multimatic 255
Reply:Naw, its more like 5 miles. It was just funny because we were having the "argon doesn't go bad" conversation at the TIG clinic a couple of weekends ago. Miller Multimatic 255
Reply:Sounds like you get all the fun customers Steve. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Steve needs a shirt that says:"Morons Flock To Me!Haha!
Reply:Louie.............didn't I say it's usually a wrong mix.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeLouie.............didn't I say it's usually a wrong mix.
Reply:Good times, good times....  Miller Multimatic 255
Reply:Originally Posted by 7A749forgot to mention they had a microwave plugged in to the aux outlets on the welder before it blew up
Reply:Not "Bad" gas...Completely incorrect gas.I think I will go out back and weld some cans together while the lathe goes round and round so I wont just stand there with my fingers up my azz...What else is there to do @ 5 AM?...zap!Last edited by zapster; 06-05-2014 at 04:49 AM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I've gotten "bad gas" twice from the same supplier.  First tank was likely C5-25.  Made aluminum impossible to weld.  Second gives me crap in the weld on aluminum, but is ok on steel.  Arc sputters. I even did a post on it, thinking my machine was busted. http://weldingweb.com/vbb/showthread.php...+with+aluminumMike Heartdoc can confirm this.  I switched tanks right in front of him, and the problem went away instantly.  But I keep touching the electric wire and shocking myself. I still get gas there cause they're very nice and super close. I returned the first bad tank half used and he gave me another for free.
Reply:It wasn't really the microwave, it was the hot butter for the popcorn that ran down onto the circuit boards when it spilled. The butter melts much faster when you have the machine topping out on duty cycle. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2026-1-1 05:35 , Processed in 0.071667 second(s), 18 queries .
