Miller SRH ###
发表于 2021-8-31 22:25:55 | 显示全部楼层 |阅读模式
I have a chance to pick up this used mahine for a couple of hundred $$.  It is a 3 phase machine & I only have single phase at home.  Can it be convert to single phase?  Any problems with running this off standard  home electricl service 220 system?Last edited by akpolaris; 10-23-2011 at 06:52 PM.Reason: missing numbers
Reply:Forgot to take the caps lock off  SRH 333
Reply:you will need to look at the voltage input needs on the tag it maybe useable on single phase and/or 3 phase... or just 3 phase onlyif 3 phase ONLY then NO can't be doneidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:3 phase transformer welder with mag amp controls.No go unless you have 3 phase power.
GMT+8, 2026-1-1 07:22 , Processed in 0.220792 second(s), 18 queries .
