Deburing Tool
发表于 2021-8-31 22:25:50 | 显示全部楼层 |阅读模式
Where can I get this tool?I was at a welding shop the other day and the owner was using one of these to debur some pipe he cut, seemed really slick. So of course I need one now, just haven't found one yet! Its an addiction I tell ya
Reply:It's a "three square bearing scraper"  Most decent tool supply firms should keep themLincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:You can make your own out of a triangle shaped file..Grind off the flutes and sharpen the edges.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zap, old files make good gasket scrapers also, years ago my father showed me that...
Reply:check out www.mcmaster.com and look up 3797A12 and see if that is what you're after.
Reply:Thanks guys, I saw this tool but had no idea what it was even called.
Reply:i like a rout-a-burr better..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:http://www.deburringtools.com/We have many different styles in the shop.The 360 degree swivel is nice and easy on the wrist.Many different blades to choose from also.Enjoy Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:Originally Posted by kustomizingkidWhere can I get this tool?I was at a welding shop the other day and the owner was using one of these to debur some pipe he cut,
Reply:+1 for the rout-a-burr. I do a bunch of large diameter castings and have found nothing faster.
Reply:Originally Posted by 4sfedI know there's not much call for poured bearings anymore, but that makes me cringe . . . kinda like using a screwdriver as a chisel.Jim.
Reply:Originally Posted by skelley521We still teach babbitt bearing pouring/scraping in our apprenticeship.I was at DuPont when they lost a large fan bearing, they flew in their main mechanical engineer to help with the problem.They started the fan and ran the unit They went ahead and ordered the bearing (25K) to have as a backup, thanked me and flew the engineer home.Lost art....pfftSometimes you just have to show that you have the skills to pay the bills Sorry for changing the subject.
Reply:The fan shaft was 10 or 12 inches and the price was for the new bearing with housing.Yes, I pass on everything I learn. Someone taught me and I feel it is very important to pass it on to the younger apprentices as they are the ones that will one day be running the show.Not to mention that they will keep my pension going once I retire also Once I hired 4 men to help me repair several smaller motor bearings, 4" shafts.The hall sent me 4 apprentices, they said they had the class, but have never done it in the real world."Good, because you are about to get a real world course and under a time schedule also."They had 5 - 8 hr days to pull the rotors; clean; inspect and replace.Scrape the bearings (90% contact); check oil gap; rebuild; couple and align to the gearbox.Everything had to be bought off by the coordinator also.They were nervous and there were times I wanted to pull my hair, but patient prevailed.They did good and learned a lot.Last edited by skelley521; 10-29-2011 at 02:06 PM.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:I found that an old worn out file is great for deburing pipe, just pull off the handle, and the curved part where it goes from the wide file to the tang, is perfect for deburing pipe from 3/8th- 1'Deereman75 from TBNLincoln electric AC225SBlueshield O/A torchSmiths aircraft torchCH 3HP 220V air compressorlots of power toolslongevity stickweld 250
GMT+8, 2026-1-1 07:25 , Processed in 0.102431 second(s), 18 queries .
