Lincoln SAE300 Questions
发表于 2021-8-31 22:25:47 | 显示全部楼层 |阅读模式
I just bought an old Lincoln SAE300 welder with a Hercules QXLD-5 Engine. Problem is someone had the carb apart and took the venturi out of the carburetor. Atleast I think it is supposed to have one. I am trying to figure out what model the carb is. All it says on it is Marvel Schebley and the letter G and the number 10 but they are not together. The code number on the welder is 1408. ANyone have anything good or bad to say about this welder. I only paid $200 for it. No gas and no spark are the only things wrong with it and I fixed the spark. Thanks in Advance,Chuck
Reply:Another $200 will buy you a Zenith carb.  You can find plent of info here.  Just search for links.No Marvel Schelbler carbs are made now.  Zenith has a better and much improved carb replacement for nearly any engine.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Welcome to the forum cbbrink  and congratulations on the SA300.Here's the operator's manual http://content.lincolnelectric.com//...r/im/IM139.pdf for your unit that is right off the Lincoln website and there are a number of parts sources for the SA series Lincolns.  Some that have been posted here before are:http://www.stumpfweldingsupplies.com/ (Ph.618-566-4733)http://www.weldmart.comhttp://www.billswelderrepair.com/Engine-Drives.htmlLast edited by duaneb55; 01-11-2009 at 03:22 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 05:35 , Processed in 0.076304 second(s), 18 queries .
