Lincoln SA250 D3.152 where to find serial#
发表于 2021-8-31 22:25:47 | 显示全部楼层 |阅读模式
Purchased a Lincoln SA250 a couple of years ago. Half of face plate was accidently torn off by helper before serial # was written down. Anywhere else I can find my serial # or code or something?
Reply:The code number should be stamped on the generator housing, look close, paint might obscure it.The serial number you are out of luck as far as I know.JTMcC.
GMT+8, 2026-1-1 05:35 , Processed in 0.101706 second(s), 18 queries .
