stuck heat range knob
发表于 2021-8-31 22:25:42 | 显示全部楼层 |阅读模式
does anyone know how to unstick the heat range knob? how do i keep this from happening again. this a  225 arc. the red tombstone box.
Reply:Try WD-40 yet? You may have to disemble, see if contact points are fused. some of these knobs are hard to turn. spray shaft only. try turning with 2 hands. You supposed to turn knob throughout its full range every time before welding. helps keep clean and free moving.
Reply:pull and turn
GMT+8, 2026-1-1 05:35 , Processed in 0.098726 second(s), 18 queries .
