hello again, I have a 1979 sa 200 that idles up very slowly when I strike an arc. does anybody have any suggestions?????
Reply:Does it do this just when striking up or is it also slow when you kick the idle switch up?
Reply:I suggest you run through the operation, troubleshooting and adjustments (including timing) of the idler. If fully understand how the idler functions and are comfortable with digging into it, check for a partially blocked needle valve or improper solenoid plunger to valve stem clearance.http://content.lincolnelectric.com//...im/IM179G1.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:it does it whether I hit my grinder or idle switch or strike an arc!!! I also cannot find any info on my year of idler on lincolns website 1979 theidler is freely moving
Reply:Originally Posted by mr welderit does it whether I hit my grinder or idle switch or strike an arc!!! I also cannot find any info on my year of idler on lincolns website 1979 theidler is freely moving
Reply:the what in the what for the what what???
Reply:Dumb question, is the carb clean and ajusted, gas fresh, and plugs clean all that good stuff?Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by mr welderthe what in the what for the what what???
Reply:no my idler is electric and I got it working better but not as fast as my buddys 1948 beat up sa200!
Reply:yes newly rebuilt carb new plugs new gas
Reply:Is it the idler for sure? Does it sound good as it ramps up, or does it hesitate as if it is leaning out? that could be idle mixture adjustment. are the points set correctly?it could also be governor response. Or binding linkage.How did it run before it was worked on?Last edited by J Hall; 01-12-2009 at 02:28 PM.
Reply:thanks for the input its running great now it was binding linkage thanks!!!!!!!! |
