Wheel Chock Made from pipe and angle iron
发表于 2021-8-31 22:25:37 | 显示全部楼层 |阅读模式
I welded this up a few years ago for something else. I didn't intend it to be a wheel chock. But it works out great as a wheel chock. I made it for a pivot point on a home made backhoe. But it didn't work great for that. I set it aside for awhile and one day I needed to chock the wheel on a trailer and grab this since it was in close range. I didn't know how good it would work. But turns out it works great. It's made from a piece of old steel drain pipe from an old house and some 3 x3" angle iron. I think that's the dimensions of the angle iron.It was just made from some scrap laying around. I might make a few more of these "accidental" wheel chocks. lolAttachment 788381Chad
Reply:The angle iron looks a bit thin and the whole thing is rough. It might serve though.
Reply:Originally Posted by mikecwikThe angle iron looks a bit thin and the whole thing is rough. It might serve though.
Reply:It being rough is just a comment on the part not the function.I imagine there is a lot of thought to the design of these things and if it is prone to push back instead of down a few inches of movement can ruin your day if you are working underneath.
Reply:I like using chocks that aren't obvious at first in case of an unauthorized person up to no good.One quick and dirty chock I saw was made with a large piece of square tubing with another piece half the size welded perpendicular to the end.  It worked pretty well.Usually I'll grab a rock or a split log.  I even have one wedge of wood that I've been using for years that has a nylon rope threaded through it because it was on the top of one of those convenience store fire wood bundles.
Reply:I like a 2x12 with a 2x8 then a 2x4 stacked. Works well for me.GravelThe difference between theory and practice is that in theory there is no difference.
GMT+8, 2026-1-1 05:38 , Processed in 0.111916 second(s), 18 queries .
