My first railing
发表于 2021-8-31 22:25:37 | 显示全部楼层 |阅读模式
Neighbor asked me to build a simple railing.  This is what I came up with.Video if the build if you are so inclined:The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Very nice!  One thing I strive for with such things is to make it look as though it has always been there; to which you have succeeded.
Reply:Nice work.... I agree, railing looks like it should have always been there.Qualified & experienced at welding scrap metal
Reply:Good job, thanks for video.MillerMatic 212, Lincoln Precision TIG 225, Hypertherm 45XP
Reply:excellent job!! looks greatMiller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Nice job John.Nice job on the video too!ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:How much space is between each baluster? At each end I'd block the opening off if it is greater than 4" as it could be a choke point for kids.
Reply:Originally Posted by pedaldudeVery nice!  One thing I strive for with such things is to make it look as though it has always been there; to which you have succeeded.
Reply:I have built miles of different railings. Watched the video, looks like you did a fine job. I do try to avoid rattle can finishes, as they seem the chalk up, and wear thin sooner. Spraying oil based enamels holds up the best in my experience. I have also used the Rustoleum hammertone in the quart cans. You can spray it can strength from a gravity feed gun with an 18 or 20 nozzle. It gives a thick coat and a lot more texture that way. The rustoleum oil based enamels spary out of the same gun, can strength, and flow out well that way too. For colors I have been using Dunn Edwards Syn-lustro enamel in the water clean up, and have been very happy with it.
Reply:Originally Posted by walkerI have built miles of different railings. Watched the video, looks like you did a fine job. I do try to avoid rattle can finishes, as they seem the chalk up, and wear thin sooner. Spraying oil based enamels holds up the best in my experience. I have also used the Rustoleum hammertone in the quart cans. You can spray it can strength from a gravity feed gun with an 18 or 20 nozzle. It gives a thick coat and a lot more texture that way. The rustoleum oil based enamels spary out of the same gun, can strength, and flow out well that way too. For colors I have been using Dunn Edwards Syn-lustro enamel in the water clean up, and have been very happy with it.
Reply:Just dont misunderstand, the additional comments were to help you grow in finishing, the main point was, you did a fine job in layout, cutting, welding, squaring, and install.  BTW, Powder coating is vastly over rated, cant be touched up easily,and is not friendly with pieces needing a field weld to install.
Reply:Very nice work!I enjoyed the VID....... I wish I could make and edit that well....Great!......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Nice work!Agape GuyEverlast Power I-MIG 200 (dual voltage)Everlast PowerArc 200 stickHarbor Freight Titanium 125 Easy FluxHypertherm Powermax 30Way too many power tools
Reply:Nice work and I really liked the video. This is not your first project I think. Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Originally Posted by FexalVery nice work!I enjoyed the VID....... I wish I could make and edit that well....Great!......
GMT+8, 2026-1-1 05:37 , Processed in 0.088875 second(s), 18 queries .
