My father bought a truck that was rolled just for its engine and now we have left is the frame and bed so we decided to turn it into a trailer like this https://www.google.com/search?q=goog...F%3B1379%3B666 now I would like some opinions and suggestions. I was thinking of using 3/32 7018s for the welding of the frame since half ton truck frames are about 3/16 thick and 7018 is a rod that has good weld flexibility and strength and for the minor non-critical stuff 6011. I have a 180 amp DC stick welder for the welding which is more than enough for the frame and material ill use which is 3/16 to 1/4 mild steel. Does anyone have any opinions, tips, and pointers? also pictures will help.Also I will practice a lot with 7018s before i use them since I don't get the chance to use them often.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:My old man would use 6010. He said it would flex and stretch better than 7018 as it would be rigid and crack at the toe of the weld. I figure he's been welding longer than I been alive and has done a dozen or so truck trailer chop do who am I to argue.sent while goofing off at workLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:One of my first welding projects as a teen was I built a trailer from the box of my Dad's '59 1/2ton Ford that our barn fell on due to snow overload.I used channel iron for the frame, a shortened house trailer axle and used the AC only Lincoln buzz box I learned on. Trailer served us well and I have no idea what my Dad did with it but he probably sold it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Just make sure you make the tongue long if it's a short bed. The axle in the short bed is too close to center and will make the trailer weave badly while towing it. Putting a tool box on the tongue will help as it will put more weight up front.
Reply:6010 would be fine for it all then? adam arc. Its a long bed truck.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Originally Posted by Adam ArcMy old man would use 6010. He said it would flex and stretch better than 7018 as it would be rigid and crack at the toe of the weld. I figure he's been welding longer than I been alive and has done a dozen or so truck trailer chop do who am I to argue.sent while goofing off at work
Reply:I think I will go with 7018s for all the main critical components to be safe.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools |
