Small combine repair
发表于 2021-8-31 22:25:11 | 显示全部楼层 |阅读模式
I picked up this 1968 Case 1160 combine last year to add to my collection. It is in pretty rough shape. It sat for several years and was worn out before that. I have a job to do with it this year so it is time to get it operating. Was a big job since most every moving part was rusted solid such as the shaft that holds the clutch throwout bearing. I could release the clutch, but the clutch didn't have enough strength to move it back. Had to take it apart and free it up. Also had to do the brake pivots and the separator clutches as well. Anyway as far as welding goes there will be quite a lot later as I get further along since there are a lot of wear through spots. This week I did the header pan that had rusted and worn through in a couple spots.I cut a bunch out and cut some patches out of a donor header. This gave me the right curve in the plates even tho I couldn't get a single piece out of the donor because of the bracing so I had to piece 2 together.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Here are the patches installed. They fit well and should work out good.I also removed the straight cut reel and sickle and added a pickup attachment because we cut the grain into windrows rather than straight cut. The pickup attachment came from the donor header. To mount that I had to extend the drive shaft and make a bearing carrier. It's all on and operational now, so I hope she holds together for the job. Got a lot more work to do on it over the next couple years to get it fully restored.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Nice repair!!!!Sweet combine...We just sold out international 403.
Reply:She's a cutie.  Funny that it was considered a "big" machine in its day.Nice work.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:That is a cool old machine. Three weeks ago I did a bunch of hardfacing work on a 9130? Case IH with a 40 foot! header. Self leveling hillside machine to boot. Pretty amazing technology there.
Reply:I think our old pull behind McCormick powered by a Wisconsin had a 5' maybe 6' head. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55I think our old pull behind McCormick powered by a Wisconsin had a 5' maybe 6' head.
Reply:Originally Posted by duaneb55She's a cutie.  Funny that it was considered a "big" machine in its day.Nice work.
Reply:Originally Posted by 7A749That's real cool. Any old farm machinery is
Reply:Nice combine. And good job putting the pickup on and having it work as desired. What crop are you planning to use it on?
Reply:welderjYou have a really: 'Gorgeous Girl'.Do the mechanical repairs to get it going . . . The collector pan is easy - do not patch - replace all of it with a single section: formed by your local farm shop..250 Arc-Air, with discreet OA, and the restoration laborwill be 'Cups & Cakes'.Opus
Reply:Originally Posted by Weld oneNice combine. And good job putting the pickup on and having it work as desired. What crop are you planning to use it on?
GMT+8, 2026-1-1 05:37 , Processed in 0.236263 second(s), 19 queries .
