Anyone have pics/plan for a turntable?
发表于 2021-8-31 22:25:10 | 显示全部楼层 |阅读模式
Looking to see if any of you guys have made or have plans for a inexpensive DIY turntable so I can rotate my piece as I weld.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:http://weldingweb.com/vbb/showthread.php...ight=turntableMaybe more coin than you want to spend though.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Ya probably. Worst case scenario I'll get an old record player and put a 45lb weight on it lol Totally kidding Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Search, use "positioner" and you'll find any number of systems.http://weldingweb.com/search.php?searchid=3126621I can remember one done with a hand wheel underneath and a simple pair of bearings to support the shaft, a few done on lazy susans, one using a right angle gearbox and so on..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Hi,I just easy build one with a brake disk,I hope my pictures can be helpfull.Demawww.ecomec.ch
Reply:Here's mine. Cheap engine stand and a headstock from a Clausing 6300 lathe. I got a killer deal on the headstock...it's actually a L00 spindle nose. I pulled the guts out to reduce resistance and weight...kept them just in case this needs to go to someone's lathe more than I need it for a positioner. Still need to work out a motor drive and possibly a pedal.
Reply:would this work for you ??
Reply:I recently saw one built with an air drive motor, a flow valve, and some pulleys.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:a friend just gave me a large ,probably 36 inch one,I have not really looked at it close yet but it is heavy duty and nice..will.post pics soon for ideas for your build
GMT+8, 2026-1-1 05:38 , Processed in 0.075673 second(s), 18 queries .
