Bought a new AHP 200x tig, it will not crank up to 200 amps
发表于 2021-8-31 22:24:59 | 显示全部楼层 |阅读模式
Hello I just bought a new AHP alpha 200x. I love the welder its self but I have it hooked up to 220V but the welder still wont crank up to 200 amps like it is supposed to. I am at a lose as to what to try next so if anybody has any suggestions I would love to hear them. thank you for your help
Reply:So what does it go up to?www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Is the crank stuck?
Reply:it taps out at 150..I thought maybe I had a bad connection with the 220 so I plugged it into the 220/110v adapter chord that comes with the machine and I was no different. so I checked my 220 with a multimeter and I checked out right where it should.
Reply:Are you sure its in tig not stick modewww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:So if you weld with it and stomp on the pedal what does the display go to?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Just checked mine, on 220, it's hovers right at 199/200 and I 117vac it's right at 140 in both AC and DC,   TIG and stickCheck you have current going to both hot legs of your plug on 200 with a multimeter.    If that's good, maybe the auto switching feature is not functioning and it's stuck on  115vac mode.  Also on ways of the primary amps is set at 200 (all the way clockwise)  should read 140 speed. As soon as you turn amp dial a little counter clockwise on either input voltage the amps should start to change on the display.Last edited by soutthpaw; 10-25-2015 at 06:37 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I'm having the opposite issue with one of mine. It reads up to 200amps on 110v and 220v. They are looking into it and getting back to me. Regardless it still welds beautifully.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Yep check your outlet to make sure you have a true 240v. Also check the wiring on your home plug and the machine.
Reply:Originally Posted by GambleSo if you weld with it and stomp on the pedal what does the display go to?
Reply:I have checked it and double checked it...still no different
Reply:maybe I will take it to another location and plug it in and see what happens..at least that will eliminate some things
Reply:Call the tec line tomorrow 1-925-391-3583www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2026-1-1 03:59 , Processed in 0.075661 second(s), 18 queries .
