HTP Invertig 221 with Quik-Disconnect fittings!
发表于 2021-8-31 22:24:54 | 显示全部楼层 |阅读模式
As always, first and foremost, Paul P. at HTP America is to thank for hooking me up with all the cool stuff.  Seeing as how he knows I have several torches, a while back he sold me some fittings that I am just barely getting to install.  Quik-disconnect's on both water lines, AND on the argon hose, make swapping water cooled TIG torches so easy I want to do it all the time!  Last edited by Oscar; 06-06-2014 at 06:35 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Oscar - Any issues with leaks or fluid leakage when you disconnect or when the lines are disconnected?The ones I am using seal instantly, only two drops of leakage each time they are disconnected under pump pressure, one drop each with no pump pressure.
Reply:Well hello there, lol.No leakage at all from what I can tell.  I haven't disconnected them while the pump is running though, only when the cooler is off.  I'm not in that much of a hurry to swap out torches that I can't flick the switch to "off".  The only leakage is from the water contained within the torch's rubber hoses, but I've come up with a quick fix for that so as to not waste any water at all from the hoses.  I have a feeling that the leakage you're seeing might be the same thing---from the hose ends and NOT the fittings, possibly. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:With the cooler pump running, if I disconnect the hoses I get a teensy weensy trickle which is to be expected.  Probably about 10 drops worth.  Obviously I'll just turn off the cooler if I need to change hoses, or just change them before I start everything. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
GMT+8, 2026-1-1 03:59 , Processed in 0.110351 second(s), 18 queries .
