more post tig clinic practice
发表于 2021-8-31 22:24:53 | 显示全部楼层 |阅读模式
after giving up on getting the water cooler going i bought a weldmark air cooled tig rig. it's rated for 150 amps but get's hot well below rated capacity. the plastic gas hose gets soft when heated and pulls away from the ferrule on the fitting and after fooling with it a few times i cut it back an inch or so then reconnected it and it seems to be holding. i found some stainless and regular steel filler rods that have been laying around the shop long before i got there. next trip to the lws i'm getting some new filler rod. Attached Imagesi.u.o.e. # 15queens, ny and sunny fla
Reply:Bottom one center looks quite nice..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Joe what kind of welder are you running that on?Miller Multimatic 255
Reply:Originally Posted by Louie1961Joe what kind of welder are you running that on?
Reply:just a question: why the torch valve? wouldn't that Lincoln TIG have a gas solenoid?Miller Multimatic 255
Reply:Originally Posted by Louie1961just a question: why the torch valve? wouldn't that Lincoln TIG have a gas solenoid?
GMT+8, 2026-1-1 03:59 , Processed in 0.074103 second(s), 18 queries .
