Need advice w/tig 409 stainless steel
发表于 2021-8-31 22:24:53 | 显示全部楼层 |阅读模式
I'm working in a production facility that makes automotive part. Tig, 409 stainless,Miller machine, 12 cup w/gas lense. I'm trying to figure out how to reduce my burn through(graying). Due to the speed needs for production there's no time to put an argon backing on each piece. Im Putting brackets on 12-16 gauge  tubing. Its proving to be a pain in the neck. When i run low amps it takes to long to puddle up and i burn through when i run high amps it almost immediately burns through.I tried setting my machine at 60  all the way up to 140. I'm doing  decent but as I come off the bracket to join the puddle to the tube I always get a little Grey hot spot on the inside wall of the tube. Any suggestions? Sent from my SGH-M919 using Tapatalk
GMT+8, 2026-1-1 03:59 , Processed in 0.072418 second(s), 18 queries .
