Can Jackson Balder WH70 Helmet be fitted with cheater lenses?
发表于 2021-8-31 22:24:51 | 显示全部楼层 |阅读模式
Thinking about buying a Jackson Balder Wh70 welding helmet.I know some of you guys have mentioned it on here.Does anyone know if it can be fitted with a cheater lens.Any info would be helpful.Thanks
Reply:Not without modification or the Jackson holder. http://store.cyberweld.com/jabamaleho37.html Sent from my SM-N900T using Tapatalk
Reply:I just wear various diopter reading glasses from the Dollar Store - at $1 each in 1.5, 2.0, 2.5, 3.0 diopters... they got me covered quite well.e.g. For Tig I want to be close in, for mig and stick somewhat further back.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:[QUOTE=gb25;4288551]Not without modification or the Jackson hThanks qb25..That is more than the salty lady from Jackson Safety that I talked to could tell me.I will get one
Reply:Originally Posted by Rick VI just wear various diopter reading glasses from the Dollar Store - at $1 each in 1.5, 2.0, 2.5, 3.0 diopters... they got me covered quite well.e.g. For Tig I want to be close in, for mig and stick somewhat further back.
GMT+8, 2026-1-1 03:59 , Processed in 0.078747 second(s), 18 queries .
