Airco DipPak 200-Need spool gun alum.
发表于 2021-8-31 22:24:48 | 显示全部楼层 |阅读模式
I have an old Airco Dip Pak 200 Mig. I need a aluminum spool gun to fit. Anybody got one for sale?? Tony.
Reply:wnywelder has one of those with an airco spool gun hooked up. if he will tell you which wires are hooked up where, i have one of the spool guns for sale.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I was told that a profax gun will fit if I take the feed roller wires and connect them to the spool gun. The plug on the Airco is a all in one gas, power, and feed wire. If I can't get a gun to fit, I need a replacement machine with and aluminum spool gun. Tony.
Reply:pm sentDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Mine has a Profax spool gun and it works great. There is a control box mounted to the top of the machine, but I can't say where the wires all go. If I get some time tomarrow, I will take a look and see if I can get some info for you.IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
GMT+8, 2026-1-1 03:59 , Processed in 0.068023 second(s), 18 queries .
