Spillage...
发表于 2021-8-31 22:24:44 | 显示全部楼层 |阅读模式
You always need cutting oil..Soluable oil mix...Etc. when making parts in a lathe or Bridgeport...Right?Well unless the machine has it's own coolant system you need lubrication/coolant at some point in time..Most times it's in a coffee can or whatever you have...And it can and will tip over and leave a big mess to deal with..SIMPLE solution to this is a big magnet!Get one that fits inside the can and just put it on the bottom and fill with your favorite liquid then place the can or whatever on the machine table or compound on the lathe and no more tipping over..Here is my fancy cookie can..Soluable oil is in the gallon jug..Magnet in front..Magnet in the can..And there you have it! Works like a charm!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i'm waiting for someone to come by and try and pick it up..and tug harder ..and then it comes flying up at him.owsplash
Reply:Originally Posted by weldbeadi'm waiting for someone to come by and try and pick it up..and tug harder ..and then it comes flying up at him.owsplash
Reply:good idea ZAP an other,,is use a ketsup /mustard type squeeze bottlesidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctorgood idea ZAP an other,,is use a ketsup /mustard type squeeze bottles
Reply:Plastic shampoo bottles are also great for lube oil and solvents.   The little squeeze bottles from my wife's hair color kit's are a nice size for air tool oil.   (I give her gray hair in return)
Reply:I just thought of doing this the other day and here you post it. Ha, wierd. I use contact lense solution bottles for some fluids and just a little stainless cup with acid brush for lathe. The cup kept moving on me so I stuck a magnet in bottom. Works great.Millermatic 252Lincoln 175 plusTA 185tswTA 161stlhypertherm pmax 45Victor torchHenrob torchAn S10 for each day of the week
GMT+8, 2026-1-1 05:36 , Processed in 0.108267 second(s), 18 queries .
