1972 sae-300
发表于 2021-8-31 22:24:43 | 显示全部楼层 |阅读模式
ok folks I need a complete air cleaner for my sae-300 it has a 226 continental I know some one out there has one ??? as the cleaner I have is not working , and for your info I live @ 5000 altitude and ice is not nice to an up draft zienith carb
Reply:I have a sae 300 welder with 6 cyl. gas and would sell it for 1400 dollars not sure if it helps but thought I would post a pic. Located northern MN. Attached Images
Reply:well thank you for the offer, but I already have 2 , there was some one on this forum I talked to that had or new were a welding supply was that had some of these machines for parts ? but I will keep in mind what you said.
Reply:did you try Stumpfs welding in southern IL?   they have a supply of old machines that they part out.  here's a link to them.  http://www.stumpfweldingsupplies.com/aboutus.htmlLocal 597 PipefittersCertified stick and tig pipe welderLincoln Ranger 305g - for saleMiller 185 migMiller Digital Elite
Reply:thanks for the link they have every thing I need
Reply:I'm glad I could help!Local 597 PipefittersCertified stick and tig pipe welderLincoln Ranger 305g - for saleMiller 185 migMiller Digital Elite
GMT+8, 2026-1-1 06:01 , Processed in 0.074671 second(s), 18 queries .
