Year Model SA-200
发表于 2021-8-31 22:24:43 | 显示全部楼层 |阅读模式
Using the code number off the welder (7307) I was able to pull up the operator and maintenace manuals. It show the official name as "SA-200-F163 (type: K-6090-SM). I found the breakdown for determing the year - but I do not understand it. Using the following serial number: A-781761 can someone tell me the correct way to break down the number to determine the year of mfg? The machine has been painted over and I am trying to do some restoration on it, so any help will be appreciated.
Reply:JayRay,Welcome to the forum.Refering to Lincoln Service Notice #9301 Bulhttp://content.lincolnelectric.com/pdfs/knowledge/Age_of_Machine.pdf, your unit was manufactured in 1975.  As the serial numbers are sequencial I would say sometime around the month of September/October of that year.  The SN listed in the column under the welder type is the first unit of the year in the lefthand Year column.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Isn't that one of those aluminum welders?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2026-1-1 07:25 , Processed in 0.110851 second(s), 18 queries .
