code 10256 invertec V300 pro to LN25 wire feeder
发表于 2021-8-31 22:24:41 | 显示全部楼层 |阅读模式
hello everyone, need some help on connecting the LN25 code 10588 wire feeder K-449with soleniod and contactor kit factory installed, to the 10256 V300 pro inverter. I guess what I am trying to say is I need the control cable K-444-2 which is a 14 pin X 14 pin X 25 feet long. BUT I cannot find this cable anywhere. IS there another part # for this cable, or not?i am wondering if this cable might be the same cable that is used on the newer V350 pro to connect LN25 to it.the invertec I have is now 10 years old, and I'm just now wanting to connect this feeder to this machine. I must admit this invertec is one h**l of a machine, SO i figured to compliment it with the LN25 feeder.If anyone could help me on this new number for the cable, it would be very much appreciated. thank you.mike.
Reply:The LN-25 is a voltage sensing feeder and does not require an innerconnect control cable unless you want to control output voltage remotely. Does your LN-25 have a 14 pin connector? Normally you would set the switches on the Invertec for output on and panel control then just run the electrode lead to the feeder and clip the voltage sensing lead to your work piece.Gary Haunemail  [email protected]  http://haunsystemsrepair.com
Reply:Originally Posted by welderdoctorThe LN-25 is a voltage sensing feeder and does not require an innerconnect control cable unless you want to control output voltage remotely. Does your LN-25 have a 14 pin connector? Normally you would set the switches on the Invertec for output on and panel control then just run the electrode lead to the feeder and clip the voltage sensing lead to your work piece.
Reply:Go herehttp://content.lincolnelectric.com/p...ture/e8100.pdfDavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RGo herehttp://content.lincolnelectric.com/p...ture/e8100.pdfDavid
Reply:David, I was just reading the manual for connection to a code 10256 V300 PRO to a code 10588 LN 25feeder (K-449) , and the manual for the machine said a K-876 X 25 ft long cable. 14 pin at invertec, and 6 pin at the LN25. this would be the cable I need, BUT, no luck finding this "K" number online or at my LWS store either, don't know what to do. would you be able to help?
GMT+8, 2026-1-1 05:36 , Processed in 0.070198 second(s), 18 queries .
