lincoln weldan power 225 charging
发表于 2021-8-31 22:24:41 | 显示全部楼层 |阅读模式
Hello, I am new here, a greatsight for welding info. I recently picked up a lincoln weldanpower 225 AC/DC welder with the onan twin engine, it needed a littlle TLC but seems to be running pretty good, I have a question though, the charging system is putting out a good charge but when running and the battery is disconected the unit shuts down, is this normal or should it be like a car that can run without a battery connected, thanxs in advance for any fedback..Bob
Reply:I have one of those.  If it works, don't mess with it.  It charges at a fixed rate.  Put a volt meter on the battery and see just exactly what it is charging at.  It should be at least 13.7 volts running on high speed.  It may not put out enough on idle to keep up.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:What David said.  He just beat me to it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanxu for the info..i put a volt meter across the battery and from not running it is 12 volts and almost 14 when at high idle..Bob
Reply:Does it still die when the battery is disconnected while running on high idle?If it does then I don't have an answer for you but at least you know it's charging the battery adequately.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:yes it still dies, it might just work that way, i have a new generac generator that wont run without a battery connected but also gives a proper charge..probably some engineer thought this up just to cause aggravation..LOL...Bob
Reply:Originally Posted by roadkillbobb. . . I have a new generac generator that wont run without a battery connected but also gives a proper charge.. probably some engineer thought this up just to cause aggravation. . .
Reply:That machine only puts out a limited # of amps.  Not much at all at idle and a max of 10 at high idle.  Not much of a regulator, but it doesn't need it because it spends most of its time welding (high idle).If it aint broke, keep fixing it till it is David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:And none of the manuals mention this, so I didnt know if it was normal or a problem, thanxs again for the info, I guess time will tell..
Reply:denrep and David R have valid points but I just thought of something.  Do you have the Fine Current Control set on MINIMUM?  If so, I suspect it's possible all charging output is being 'consumed' by the field flash circuit and thus killing the engine when the battery is disconnected.  Setting the FCC to MAXIMUM would confirm or disprove.  Just a thought if you're still curious.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If that machine has coils powered by the battery then unhooking the battery will result in a stalled motor. The japs use this system on several of their motorcycle and it works well. If an engine quit for no reason the first thing we would check is batt connection. There shouldn't be any reason to unhook the battery when the engine is running anyways.
Reply:yes the current knob is set at 10 max, I only played around with the battery disconnecting because it came with a dead battery and I was just curiouse to see if the engine would run without the battery I put a good battery on and during use it will stay connected, and yes there is a coil with points..
GMT+8, 2026-1-1 07:22 , Processed in 0.115190 second(s), 18 queries .
