Question on a WP 250 G9 Pro
发表于 2021-8-31 22:24:41 | 显示全部楼层 |阅读模式
I have a Lincoln WP 250 G9 PRO   Code 9181   SER.# A1120412. It has two 20amp 230v receptacles, the newer models have one 40amp (39amp) receptacle. Can a single 40amp receptacle be wired into this machine safely? Any help or advise would be appreciated. I tried the Lincoln site, but I was having difficulty with it, most likely my error, but I could not find my answer, or a diagram. How do I navigate their site to find the year of this machine?Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Originally Posted by tessdadI have a Lincoln WP 250 G9 PRO   Code 9181   SER.# A1120412. It has two 20amp 230v receptacles, the newer models have one 40amp (39amp) receptacle. Can a single 40amp receptacle be wired into this machine safely? Any help or advise would be appreciated. I tried the Lincoln site, but I was having difficulty with it, most likely my error, but I could not find my answer, or a diagram. How do I navigate their site to find the year of this machine?
Reply:Do you mean a suicide type adapter, with two male 230 volt-20 amp cord end connected to a single 230 volt 50 amp receptacle?Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Originally Posted by tessdadDo you mean a suicide type adapter, with two male 230 volt-20 amp cord end connected to a single 230 volt 50 amp receptacle?
GMT+8, 2026-1-1 05:45 , Processed in 0.104573 second(s), 18 queries .
