Coffee table idea.
发表于 2021-8-31 22:24:40 | 显示全部楼层 |阅读模式
Saw this in the doctors office looks easy and cheap. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Looks cool.
Reply:Theres a lot of Industrial retro stuff about nowdays, its all part of the recycling crazeLook at this table made from an old water tankSome very clever and crazy ideas here https://www.google.co.uk/search?q=in...w=1920&bih=955
Reply:I love the idea of black pipe, but the fittings are not cheap here. I would spend a tenth the cost if I was doing it out of mild steel. That being said I have used pipe for various and sundry projects like this... Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Check this table I just built for a guy. It is made from a grapple to pick up hay bales. It was his idea, I just welded it up and put braces in the ends to stiffen it up. He put a large slab of mesquite on the top. Every one that came into the shop called it the spider table. Attached Images
Reply:Looks cool.  And they probably way overpaid for it.  I think I saw shelves like that made from black pipe in restoration hardware for a silly amount of money.
Reply:Originally Posted by BobCheck this table I just built for a guy. It is made from a grapple to pick up hay bales. It was his idea, I just welded it up and put braces in the ends to stiffen it up. He put a large slab of mesquite on the top. Every one that came into the shop called it the spider table.
GMT+8, 2026-1-1 06:01 , Processed in 0.069152 second(s), 18 queries .
