bench grinder pedestal
发表于 2021-8-31 22:24:39 | 显示全部楼层 |阅读模式
I came across an old 'Cincinnati' Bench grinder and decided to rehabilitate. Originally the stand was gonna be pipe, but I wanted to mount an outlet in it,which tubing is more accommodating. This is what I ended up with. Attached Images
Reply:How did you bend the pipe to make it fit the square so well?GravelThe difference between theory and practice is that in theory there is no difference.
Reply:No bending at all... 3-1/2" square tube to 4" pipe, I just butted them up and filled up the gap.
Reply:Wow! That is really nice! Simple but different.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:That is a work of art!  Best  Bob
GMT+8, 2026-1-1 05:38 , Processed in 0.097923 second(s), 18 queries .
