Pipe fence done
发表于 2021-8-31 22:24:37 | 显示全部楼层 |阅读模式
Just finished another run of pipe fence for a customer. This is the second run of fence for this man. Start the next run in a couple months. Doing about a thousand feet at a time. Here's some pics. Attached Images
Reply:Hey Bob,good to see you posting again, you been ok?Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Hi Bob.  Looks like a Miller on the bed of your truck.  What process did you use for the fence build, stick???  If so, what type and size electrodes did you use?   Thanks.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:I always go with the 1/8", 6010, 5P+ for this. It makes it easier welding the rusty pipe to the galvanized panels. The gates were done with wire in the shop.
Reply:Looks great!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Nice.  No bottom pipe?  I've never built a fence like that so I don't know if the bottom rail is standard or not.  Does the electric fence come down now that the main fence is built?  Do you also stretch and fasten the wire mesh as part of the contract?  Thanks for sharing...Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
Reply:I believe its actually stiff panels rather than wire mesh... I don't think you could weld it if it was wire.  Bob, how much do you typically charge per foot for a fence like this? I've done a couple that looked identical to that but it was for close friends so they got the "friend rate" anyway.I’m just happy to be here!
Reply:Originally Posted by WenValleyNice.  No bottom pipe?  I've never built a fence like that so I don't know if the bottom rail is standard or not.  Does the electric fence come down now that the main fence is built?  Do you also stretch and fasten the wire mesh as part of the contract?  Thanks for sharing...
Reply:Nice fence and nice rig! Cant go wrong with a square.Everlast 200dx
Reply:Originally Posted by dieselcowboy460I believe its actually stiff panels rather than wire mesh... I don't think you could weld it if it was wire.  Bob, how much do you typically charge per foot for a fence like this? I've done a couple that looked identical to that but it was for close friends so they got the "friend rate" anyway.
Reply:Originally Posted by BobI charged $13.80 per foot for this one and that included holes and concrete. The gates were extra. I came out right on it.
Reply:That was material and labor not to include the holes. It's hard to price holes when you don't know what is in the ground.This fence was also screwed together at the joints. Nicer fences, say out front of a house, then the threaded joints get cut off and welded. I like to set the posts on 10'. The pipe is usually 31 to 32' long. At 10' spacing the welded joints can be put right on top of the posts and won't be visable in changes of grade. The welded wire panels are 20' so the panel splices will be on a post as well. These things just make it much neater and the fence will look better as well.
Reply:Thousand feet at a time too, that's a nice pay check.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by Doug247Thousand feet at a time too, that's a nice pay check.
Reply:Ran this fence last year in Clifton Tx 600 ft. The owner 65 his partner 67 & I was 74 at the time. ran it in 4 days. I see you have a 301 Trailblazer, I have one too. Attached Images
Reply:Makes me miss central Texas... But not the fire ants..MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
GMT+8, 2026-1-1 05:36 , Processed in 0.072615 second(s), 18 queries .
