Test weight manufacturing
发表于 2021-8-31 22:24:36 | 显示全部楼层 |阅读模式
I WANT TO MANUFACTURE SOME TEST WEIGHTS OF 5T TO 1T, BUT NOT FROM CAST. INSTEAD I WANT THICK METAL SHEETS TO PLACE ONE ON TOP OF THE OTHER AND GET WELDED. IF THE SHEET THICKNESS IS 100mm AND ABOVE, I'D LIKE TO KNOW HOW CAN IT BE WELDED WITHOUT GAPS OR BUBBLES IN THE MIDDLE AND THE POSSIBILITY AND SUCCESS RATE .THANKS IN ADVANCE
Reply:Huh?.
Reply:Originally Posted by spantoI'D LIKE TO KNOW HOW CAN IT BE WELDED WITHOUT GAPS OR BUBBLES IN THE MIDDLE AND THE POSSIBILITY AND SUCCESS RATE .
Reply:drill regularly spaced holes and plug weld it
Reply:Turn off the capsWhat is the sound of one knee jerking?
Reply:Everyone is probably sitting at a computer with their ear plugs removed. There is no need to scream  , i.e turn off the caps lock
Reply:sorry for the caps and thank you for the info.really appreciate .
GMT+8, 2026-1-1 05:46 , Processed in 0.212769 second(s), 18 queries .
