7018 without looking
发表于 2021-8-31 22:24:33 | 显示全部楼层 |阅读模式
I also have a 6011 and a 7018 vertical up without looking...i been stick welding since the age of 8....
Reply:What is the purpose?
Reply:Showing how simple it is...
Reply:I would think looking is simpler but wtf do I know. I would like to see this for a 16 hour day.
Reply:Originally Posted by kguit34Showing how simple it is...
Reply:Anyone can drag a 7018 rod flat, in a fillet....literally a monkey could be trained to do that. But welding involves reading the puddle, not just burying the arc and praying for fusion, tying in to both walls, with no undercut and uniform bead...This reminds me of the video of the pipewelder lifting his hood while running a root on a o-let. I mean yea its pretty easy sometimes where the rod "runs itself" on a root pass when the root opening is right and your heat is perfect, but I rather see the keyhole and KNOW that Im breaking down both walls and tying in...So basically prepared to get flamed big time
Reply:You save a lot of money on clear lenses and those filters. Head never gets to hot from being inside a helmet. I'm in! Now strut your stuff and show us some overhead welding.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:If you set it right you could set the stinger down and just come back in a minute...Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by kguit34I also have a 6011 and a 7018 vertical up without looking...i been stick welding since the age of 8....
Reply:Lots of bare skin on the face and arms area. Not good.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:No harm done, I'm sure.
Reply:Originally Posted by 7A749Says video private now.Darn, missed all the fun.
Reply:I can do that any process. I just tell one of my guys to do it, then walk away!
Reply:Years ago I worked with a guy, who always said. He could weld just as good with or without a hood. Just without the hood he couldn't weld as long.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by MikeGyverIf you set it right you could set the stinger down and just come back in a minute...
Reply:i saw a picture someplace of someone manning 3 or 4 very long arc welding rods propped up on a spring loaded lean to device welding in the flat position. i think he was using this to weld stiffeners in a shipyard and the rods were burning almost un-attended.i.u.o.e. # 15queens, ny and sunny fla
Reply:Makes me feel better about my welds   the wrong thing to post on this site,these old pros have no censor. Get your heart off your sleeve and let these guys see it. I watched it last night not sure what the point was.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:No helmet, short sleeves, open neck, seems like a good way to get skin cancer and cataracts.
Reply:Geeeee..I miss all the fun stuff.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Maybe the thread needs to go away with the video?
Reply:Don't be hay-in.
Reply:Originally Posted by geezerbillDon't be hay-in.
Reply:YAYYYYY ! BUUUUUUUUUUUUUUUUURP Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Mick is right on with the '' STUPID ''. Video worked for me now. Great safety, no hat or long sleeves and I like the way he tries to shield the sparks with his left hand. It appears he really wants to look too without the hood. Not to mention all the sparks spattering the inside lens of the hood. I doubt if he has a clear plastic lens on the inside.
Reply:Make you one of these so you can look.
GMT+8, 2026-1-1 05:53 , Processed in 0.098469 second(s), 18 queries .
