I just recieved my hand remote box from SSC Controls. It is very nice and it showed up exactly when they said it would. Bought it for two reasons,-Watching Fieldres & other pipeline videos (Hoping that magic box will make me a better pipe welder)-Figured it would be nice to have a remote outside vs running in the garage every time I want to change the setting when running stick or the suitcase.I wanted to check it out without welding anything so hooked it up to the XMT and switched from panel to remote. When in an electrode hot position, turning the dial on the box does nothing to the output amps or volts on vs feeder setting. The knob on the welder still functions. When I switch it to a non electrode hot position the knob on the box adjusts the amperage or voltage depending on the process. Shouldn't the output change when the dial is turned on the electrode hot mode? With my foot pedal on lift arc tig, I set the max amps and stepping on it does nothing on the readout until an arc is lit. Is this how the hand control works?When the on/off on the remote switch is in the off position the welder is quiet. When you turn it on there is a humming sound. SSC says that switch is a contactor control but what exactly does it do? Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:^^Bump^^Sent from my GT-P3113 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:I wish they had these remotes when I was working. Sometimes you might be 3 to 400-feet from your welder. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Really CEP, one for each welderShowing off that nice Invertec again I see. Your starting to make me like red more and more.Sent from my GT-P3113 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:I never used an XMT, I'm sure they are pretty much the same thing as the V350-Pro.Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:They don't have all the nice fancy lights on the front. They also have a de rated duty cycle on 1 phase power.Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:My XMT and its manual are 1100 miles away, but I think that is the difference between "Stick" mode and "CC" mode. In Stick it's panel control only; CC mode is for stick with an external remote.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Thanks for the info Steve. I think I will like being able to change settings away from the machine.I guess with the remote for stick I need to run it in cc remote non electrode hot.When I have the 12vs connected, could I run it in mig mode and use the remote to adjust voltage? Or should I still have it on vs feeder electrode hot with the panel/remote switch on remote?Played around with it a little before lunch and this is how it went,Process in cc (guess that's stick remote) Contactor switch off.Attachment 742991Same process selection, contactor control on, remote knob in a different spot.Attachment 743001Mig, contactor offAttachment 743011Knob turnedMig contactor onSent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE |
