Dedicated Grinding Wheel???
发表于 2021-8-31 22:24:31 | 显示全部楼层 |阅读模式
Ok so I bought a dedicated diamond grinding wheel for tungsten grinding. Can this be used  for tungsten that are for carbon, ssstainless and aluminum or do you a separate wheel for each kind of metal?
Reply:I have always used the same grinder for any tungsten.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:My buddy is a pipe fitter/x-ray quality welder, uses the nearest flap disk. Just sayin..........."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:After getting a tungsten grinder, I'll never use anything else!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Mastering others is strength, mastering yourself is true power.
Reply:I use the same grinding wheel for any type of material I'm welding.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by lstilts
GMT+8, 2026-1-1 06:02 , Processed in 0.112300 second(s), 18 queries .
