查看: 13|回复: 0
Tweco/Thermal Arc 141 ???
发表于 2021-8-31 22:24:30 | 显示全部楼层 |阅读模式
To those who own one.......what are your thoughts and opinions ?
Reply:I have an Thermal Arc 211i and like it. It's just a little larger than the 141i. It is my first time using a mig welder /3in1.  Bob
Reply:Love my 211i.Its been welding nearly everyday for about a year without any trouble at all.An excellent value for the price.Sent from my HUAWEI Y300-0151 using TapatalkUsing Tapatalk
Reply:I see by your signature you have almost every Ta machine known to man. Why the 141? Collecting the set? Not that there is anything wrong with more toys. Do you like your 95s have you used it for tig welding? I'm looking to update my 80a inverter to one that is a better machine.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:I love mine. Few things I dislike but it's a good machine this far. Haven't run a ton of wire through it yet. For want ever reason the first tip lasted less than 1 pound of wire and the liner is **** already. Threw on a new gun and it's like a new machine. Probably going to ditch this fusion gun and stick with a gun with tweco mini front end parts.I am going to play with it in a few just to make sure the new gun is working as it should and it was the old one that was junk.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by Austin BennettI see by your signature you have almost every Ta machine known to man. Why the 141? Collecting the set? Not that there is anything wrong with more toys. Do you like your 95s have you used it for tig welding? I'm looking to update my 80a inverter to one that is a better machine.
Reply:Originally Posted by rahtreelimbsTo those who own one.......what are your thoughts and opinions ?
Reply:Scott,Thanks good info....,iv read another post some time back where after a gun change it welded like a different machine.. so much for there new fusion gun design..what does it have to do with gas flow?Esab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:Originally Posted by jim cafarelliScott,Thanks good info....,iv read another post some time back where after a gun change it welded like a different machine.. so much for there new fusion gun design..what does it have to do with gas flow?
GMT+8, 2026-1-1 07:49 , Processed in 0.072363 second(s), 18 queries .
