Thermal Arc Power Plus TA 10/270
发表于 2021-8-31 22:24:26 | 显示全部楼层 |阅读模式
I have this Thermal Arc Power Plus TA 10/270 that I received a couple of years ago.  It had a bad fuel solenoid on the Honda carb. so I replaced it and the unit works perfectly.  I've replaced the plugs, oil, and filter and tested the welder and power outputs.  The unit works great.  It starts immediately, and runs perfect.  I have no real use for the unit, so I figure I'll sell it to buy a Toyota 4x4 for my next project.I'm asking $2,000.00 obo. for the unit, it's on wheels, but not a pull-behind trailer.  Obviously, it's local pickup only deal because of the weight.  I also don't have the welding leads for it.  I could probably find a set if I need to in order to sell it.  It has 305 hours on in.You can contact me on here, or by phone at (209) 627-0467.  It's a Google Voice number and goes directly to voicemail, so leave a message and I'll call back immediately.Last edited by Torkrench; 03-21-2011 at 01:39 AM.Reason: not displaying properly
Reply:where are you located?_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Sorry, I guess I forgot to mention that.I'm in Tracy, CA  (I'll edit the original post too)
GMT+8, 2026-1-1 06:02 , Processed in 0.110944 second(s), 18 queries .
