new to me hobart stickmate
发表于 2021-8-31 22:24:24 | 显示全部楼层 |阅读模式
I found one hell of a Craigslist score. Got it for around 100 bucks with extras like welding rods and two helmets. added some tweco 2mpc plugs on it to replace the tired leads and so i can use my leads for both the ideal arc and the stick mate.best part is it is still made in the USA also needless to say i won't be needing to buy any kinds of welding rods for quite some time.also anyone got pictures of the carts they have made for theirs? I wanna make a cart kinda like what you see on the big gas powered pressure washers. its got to be able to be moved easily over dirt grass tree roots the like.2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:Ok... I think that score gets a well deserved, "You Suck!" lolWow, congrats on that one! Can't help with a cart cause I didn't keep mine long enough to build one before I scored the Idealarc.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:you stole that sucker. the welder was free. you just paid for the rod. good little machine. i bought one for the shop for just the small stuff and so the boys could use it to learn without burning gas in the miller's. i built a plain jane cart for it but didn't take any pics. if i have the time tomorrow i'll pull it out and snap a couple pics.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Not quite sure why you need that with the idealarc 250, but at that price you really couldn't go wrong. You can easily sell that for twice the money if nothing else.With all the rods, looks like you cleaned out a store shelf. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That's a great deal! A while back,I was looking for panel mount connectors likeyour twecos,never found any.I bought Lenco lug type that I plan to install on myT-Bolt.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Your Idealarc has much more umpff and a much higher duty cycle than the stickmate does. I would resell the stickmate for double what you paid for it and keep all the rod.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I consider myself in a better position to off a YOU SUCK!!!! than many of the guys here since I am also in Virginia.Great find - I love my stickmate.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:fhsfiremanco1...What A Steal!  Hell of a Deal!$100 for that new welder is quite fantastic!Cripes... new and full paks you got $270 worth of electrodes there!No wait... don't tell us... the two welding hemets that came with it... are auto-darking hoods? Why this and not the Lincoln IdealarcSimple WEIGHT!  100 lbs versus 350 - 400 lbs.In no way can the Idealarc be considered portable!  That's it's Acheales heel.fhsfiremanco1 said it, "anyone got pictures of the carts they have made for theirs? I wanna make a cart kinda like what you see on the big gas powered pressure washers. its got to be able to be moved easily over dirt grass tree roots the like." Picture that with an Idealarc!!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Ricks got it I wanted it to hirt in the yard. The 180 is old and ac. I've pushed the ideal arc in the yard it sucks for it. I saw this and I figured what the hell. It's worth it just for the rods. Plus it doesn't pull 23 amps just sitting there on. I'll break out the big boy when I need the power and duty cycle2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:You could put an switch on your Idealarc to switch off/out the power factor capacitors when the machine is sitting at idle; switch them in/on just before you light up an arc and off/out again when done = best of both worlds.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:VERY nice dude!! Those are great welders, I love mine.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:rick v if i was gonna flip a switch i would just turn it off  lolLance is your stickmate kinda loud? i think i may need to grease and tighten the shunt. it sounds kinda mad but no diode loss or shorts checked all that and even welded with it in ac and dc2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:Yeah, mine always sounds pretty mad, I think thats just the way they are.But it sounds a lot madder when one of the screws vibrates loose and the cover rattles, you might wanna check and just make sure they are all tight. Got any projects in mind for this thing? [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:yea the cart for it and whatever projects come up. nice little welder but I can feel the different in power to the ideal arc still a keeper tho and at that price how could i go wrong? I could still sell it in a couple years for twice what I have in it. the rods alone are worth $300 or more those little pack are like 8 bucks a piece!Anyone want pictures of the cart build this weekend or have y'all seen enough welds and carts maybe even some wiring?2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:no pictures of the welds and the build but here is the out come. just want i needed2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:doubleLast edited by fhsfiremanco1; 11-15-2011 at 10:54 PM.2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:hows the wife or gf like the new end table?225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I think the Stickmate wants to play "Fetch", I see he already brought the ball
Reply:its the "mans" room off of the garage it had better light and thats where me and the dog spend alot of time2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:Enjoy it in good health.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I think it's going to be a long time before some one beats this CL STEAL! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
GMT+8, 2026-1-1 06:02 , Processed in 0.107628 second(s), 18 queries .
