another Craigslist score. HF Mill
发表于 2021-8-31 22:24:23 | 显示全部楼层 |阅读模式
Picked this up for $80 just a couple miles from home...   perfect for what I want to do... Custom stuff for my RC vehicle stuff.  need to get a 1"side cutter so I can make it fit standard hold downs.  its only 5/8" wide and I need 1 inchThe table is level end to end but a bit of a wobble in the crappy HF chuck.  need a decent MT2 chuck.   need to get some MT2 collets now for the millsLast edited by soutthpaw; 11-13-2011 at 08:43 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Wow, $80?? good for you!
Reply:Calling it a mill is being a little generous with the description.For an $80 drill press with a nice table to position work, I would have bought it too.My name's not Jim....
Reply:agreed ^.Its a nice tool with a compund slide table though. I dont know if I would "mill" with it. If I did it would be very light cuts. Drill chucks arent designed to get side loaded like thatHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:It might work for what southpaw wants - with endmill holder and draw bar.  The chuck will come out and jack up you work. If our table does not move easily, then it will be very unpleasant making passes.  Like much of HF stuff it the tool can become a hobby just making it function properly.. Check yahoo groups for info.Worth 80 bucks, though.
Reply:Originally Posted by tapwelderIt might work for what southpaw wants - with endmill holder and draw bar.  The chuck will come out and jack up you work. If our table does not move easily, then it will be very unpleasant making passes.  Like much of HF stuff it the tool can become a hobby just making it function properly.. Check yahoo groups for info.Worth 80 bucks, though.
Reply:And then the end mill will slip out of the chuck because a drill type chuck just won't hold tight enough for the side load and vibration that develops during the milling process$ 80 bucks for it is a good priceBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11And then the end mill will slip out of the chuck because a drill type chuck just won't hold tight enough for the side load and vibration that develops during the milling process$ 80 bucks for it is a good price
Reply:Hey guys,If you don't HAVE one, or never USED one, please refrain from spouting your baseless comments regarding that mill/drill. Opinions you are entitled to, although, are meaningless without a "hands-on" experience.I have a similar mill that I got, new in the crate, shipped without any damage for less than $180 & has performed flawlessly & with great accuracy & has done every type of milling I need. The proper application of usage & material has to be understood regarding mill feeds/speeds/amount of material cutting to obtain desired results. Same as a welder.....amps, material thickness, type of metal...... simple, eh? You use it with the understanding of limitations. I see that it is a 1/2HP unit & mine is a 3/4HP, so I believe it will do as well as mine.southpaw:  Get a good Jacobs chuck as I did & that will eliminate the weak/soft import-made chucks that wear out fast. As long as you take your time with steady feeds & material(steel) cuts <.125, it will serve you well. A mill is a superb unit to do some machining/fabrication that many need on occasion & when space is premium & can be a limitation for a large mill such as a Bridgeport, these bench mills can fill a need. These units will mill aluminum, brass/copper, & the softer material quite handily with excellent results & precision. Don't underestimate them.....    Here's some pics of some of my projects milling & the monthly milling I do on the doorframes(latch slot) I make for my old boss's contracts he still gets. Those doorframe slots are .125 thick & I do them in one pass with ease & get a nice finish.Denny Attached ImagesComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Thanks, I will get some collets for the little milling I will use it for.  Nothing major,  I was cruising craigslist for a small drill press and found this.He included that box of end mills in the deal too,Last edited by soutthpaw; 11-14-2011 at 09:12 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Super Score Soutthpaw!  Another amazing Deal from the Master Wheeler-Dealer! Yorkiepap, thanks for your post; it shows that this is quite a machine for either $180 or $80!  Wish I had one... Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick VSuper Score Soutthpaw!  Another amazing Deal from the Master Wheeler-Dealer! Yorkiepap, thanks for your post; it shows that this is quite a machine for either $180 or $80!  Wish I had one...
Reply:Originally Posted by soutthpawwell quit buying so many welders and start looking for machining tools
Reply:Originally Posted by Rick VMe...?  I stay on topic - this is a welding forum - not a machinist forum. You... your Master Wheeler Dealer title on Welders may be up for challenge from fhsfiremanco1... http://weldingweb.com/vbb/showthread.php?t=62631 Southhpaw, I worry you are surcombing to the Forces of the Darkside... first the Everlast 140ST and now this obviously Chicom drill/mill.  Tsk, tsk, tsk..."Are these the Droids you're looking for?"
Reply:Yorkie:I can't figure out from your pics if you are milling with the EM in a collet or a drill chuck. The close ups look like a collet but your first pic looks like an EM in the chuck.
Reply:For $80, it's a beautiful purchase.  Wow....why am I never at sales like that?Enjoy it!NelsonHobby-Machinist.com - The Friendly Machinist Forum®My toys: South Bend Heavy 10L Lathe (1973)Burke #4 Milling Machine (1946)Van Norman #12 Milling Machine (1942)South Bend 14" Drill Press
Reply:Hey dune,That is a Lewis chuck, one of several I had when I had my Bridgeport as I've seen the weakness of most of the flimsier imported chucks. It has never had an EM come loose. They aren't cheap.......just the best and a good Jacobs 2nd place. Here's where they be had....http://www.baileysonline.com/itemdet...utm_medium=cseDennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Cripes!  That chuck is $200!  That's more than you paid for the machine!No reflection on you cause you already had it but to buy it new... kind of like putting a $300 hood on a $5 head! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:doesnt the mill/drills have an r8 spindle?tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by Rick VCripes!  That chuck is $200!  That's more than you paid for the machine!No reflection on you cause you already had it but to buy it new... kind of like putting a $300 hood on a $5 head!
Reply:Hey Rick,Yeah, they're expensive today. When I bought my Bridgeport back in '74($500), the 'ol timer I got it from gave me every attachment/accessory he had with it. There were (5) Lewis chucks along with a couple Jacobs & a complete collet setup. When I sold the Bridgeport, I kept all the accessories. Yup.......came in handy.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:There is a Pawn shop in town that specializes in tools and they have a bunch of that kind of stuff so will check there for a good chuck.   I did check the runout and its perfect at the mt2 taper but the chuck is .005 out at the end of the jaws with a mill in it.   Thanks to tapwelder, he is sending me a couple of MT2 collets for the price of shipping.  so just need a chuck that decent and I am set to go...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by yorkiepapHey guys,If you don't HAVE one, or never USED one, please refrain from spouting your baseless comments regarding that mill/drill. Opinions you are entitled to, although, are meaningless without a "hands-on" experience.
Reply:Originally Posted by fordmanFair enough I just dont want to see someone try and mill with a drill chuck. NOt saying he will but I have seen it done when I was in school. Flying tooling when it breaks off can be scary
Reply:$80 for a mill/drill?You suck.    The best laid schemes ... Gang oft agley ...Props to Tapwelder who hooked me up with a couple of MT2 collets for $11 in shipping...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Nice to have helpful friends!Soutthpaw, I await the posting of another new arrvial at your place... or do you already have a nice USA made 10 - 14 inch lathe?It's right scary, this progression from welders to machine tools.Hmmm, have to talk to a machinist and ask him, "What comes after machine tools?" Does it never end?  Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:a lathe is on my automatic Cragislist search.. HehTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2026-1-1 06:02 , Processed in 0.076848 second(s), 18 queries .
