Rotary Table
发表于 2021-8-31 22:24:22 | 显示全部楼层 |阅读模式
I need help on a source for a inexpensive rotary weld table. I does not need to support alot of weight about 5 pounds. Mig welding .25 wall tube to .25 plate ThanksJeff
Reply:Originally Posted by schiada96I need help on a source for a inexpensive rotary weld table. I does not need to support alot of weight about 5 pounds. Mig welding .25 wall tube to .25 plate ThanksJeff
Reply:Google "positioner" and start shopping. As was pointed out, they are not cheap but they open up another weld option that you can't match freehand. You should be able to pick one up for 5 - 7 hundred ready to go in that small size. Good LuckAnything worth doing is worth doing RIGHT
Reply:Build one maybe? Shouldnt be to hard and it wont be to much money.
Reply:anybody know of one I can pick up for around $700
Reply:Well, I was checking out a new one a while back. 14" table, 200Lbs vertical and 100Lbs horizontal, motor drive .1 to 40 RPM, reversable with a good foot control, manual elevation control (handcrank). $1295 NEW without chuck, many machine shops have those used that they'll sell.I don't know why, given the prices of new table mount systems, you couldn't find a smaller used one for less. Factory closures are the cheapest, with some of the auction sites coming close in price. There's no location given in your post but if it's a populated area there a many smaller shops selling off stuff just to stay afloat. On the other hand there are small shops that sell off stuff they opened with as they scale up (grow).Last edited by olddad; 06-26-2007 at 04:43 PM.Anything worth doing is worth doing RIGHT
Reply:Just a thought for something cheap. How about a clay pottery table. It would hold 5lbs. and has a foot control for speed You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:Originally Posted by MB2005Just a thought for something cheap. How about a clay pottery table. It would hold 5lbs. and has a foot control for speed
Reply:Jeff,If this is for home use, not production, you may want to just try using a lazy susan base with a piece of 1/4" plate mounted on top.  Rotation would be by hand, which would work if you're using mig.The seat base used on bass boats (available at most any marine supplier) would be a good start.If you cut the base circular with a plasma cutter, you could use a small, variable speed moter with a rubber drive wheel attached to the shaft and mounted so it contacts the outer rim of the base.Just a couple of options that would't cost a grand to do."Many" years ago a company that made the old "erector sets" made a variable speed motor (heavy duty) that would have been perfect.  I know, because I built a crane using that motor.
Reply:Yes sundown now that's what I was getting at. Good old yankee engineering. How about a rheostat in addition to a variable speed motor to fine tune the speed. With the right gear ratio you could have a nice compact positioner.Try to look at the glass half full, Zap  lol. Always shooting down good ideas. You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:I was gonna say, why not build something simple like that. It wouldn't require a lot of precision to be effective, and you could probably get all the parts from ace hardware if you think the entire assembly process through, heh.
Reply:Originally Posted by MB2005Try to look at the glass half full, Zap  lol. Always shooting down good ideas.
Reply:I thought this guy was getting this for his home shop. My comment to Zap was in fun. Im sure he knows more than me. Just noticed he gets into it alot for shooting down ideas. If this is for a pro shop I agree that a good unit should be purchased with no expence spared. Any good tool will pay for itself over and over again. I only offered what I would do if I needed a cheepo. You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:I came across this earlier today and it looks pretty cool so I thought maybe you guys would also like to see it.Check what the guy Scott made at post #9http://www.millermotorsports.com/mbo...ead.php?t=8296Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:Thanks Phila, If I saw that piece of hillbilly engineering in some ones shop I would definately want to use them. A little beefy for 5# projects, but thats what I was talking about. You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:MB2005, the original poster says nothing about the frequency of use and his profile says nothing either. SO, you could be correct on your assumption of home use.Nothing wrong with your idea, just have to find a different motor or have that one rewound maybe ? Everytime I've tried to slow a motor down below what it's designed for I've burnt them up. But then the only thing I know about electrical is simple home wiring so it could've just been me.As for the pro's and "no expense spared", you have to weigh the use against the cost. I use a welder manufactured in 1984 and just recently bought another in case this one dies on me. I could pass X-Rays all day long with this old hunk and there isn't much that's more critical than an X-Ray unless you take the stuff to a lab.Long winded huh...anyway...good idea that just needs tweeking.Anything worth doing is worth doing RIGHT
Reply:Olddad,If you read my post, I started it by saying "if for home use".  Don't think I could have been any clearer.Seems to me, if it was for production use, the original poster would have done some research on "professional positioners" and maybe asked the question differently.  Such as, has anyone had any experience with ____?My concept, I believe, would work for occasional/hobby use.If one wanted to carry it a step further, you could look for reduction gearing from an old grandfather clock.  That along with a variable speed motor would get the speed down to that necessary.I am an engineer by training, so I've always looked for the "how" and "why".  I agree, the easy solution would be to "order a function designed positioner".
Reply:SundownIII, I'm at a loss here, I can't figure out where I referenced your "lazy suzan" or your "bass boat seat base" ?? And yes, your concept would work as you surmise for a one handed operation such as mig. Since you brought it back up there is one thing I'll point out though. There is no way without a dedicated speed control to maintain a consistant, fluid bead around the whole part. You will reduce the post weld clean-up time on the diegrinder but you will not eliminate it. Isn't, afterall, that the purpose of the positioner in the first place, to reduce the "start/stop" points to one while maintaining a uniform bead ?Anything worth doing is worth doing RIGHT
Reply:I'm a home-use guy and sometimes a lazy susan type thing would be nice just to be able to reposition something as I weld.Ha ha ha, there, I added fuel to the (inane) fire.Make a homebrew one that will be semi-sucky or buy a decent one if you need decent. There, I ended it.- John
Reply:Jeff, check out the Catalog # DCM-315 gearhead motor sold by All Electronics in the Los Angeles area.  4.6 RPM, 120 in-lb gearhead, driven by a moderate size 24 VDC 0.90 amp PM motor.  5/8" diameter output shaft.  $79.00.  You only have to supply a variable DC power supply, a turntable, and weld up a fixed table or an adjustable bracket if you want to be able to tilt the axis.  See listing:http://www.allelectronics.com/cgi-bi...AR_MOTOR_.htmlThis gearhead could probably carry 100 pounds or more (wild guess), but the price is right.For power, this bench power supply is overkill, but available from the same outfit:http://www.allelectronics.com/cgi-bi..._0-3_AMP_.htmlYou can find a suitable 0-24 VDC power supply much cheaper elsewhere if you shop around.  The 0.90 amps cited in the motor listing is undoubtedly with no load, so you probably want 3 amps or more power supply capability in case you load down the turntable and for starting up.  With the digital voltage and current displays, you could repeat the speed setting fairly precisely.Rather than going to the hassle of fabricating brushes for the ground connection, I'd just use heavy braid from the table to ground and let it wrap around the shaft a few turns.  You'd have to set up some way of being sure not to let the motor wind the ground strap up tight because the motor has enough torque to rip it loose or do some other damage if left running.  I'd rig up a switch to shut the motor off if the braid would up too tightly.Large wind turbines sometimes use this technique (dangling cables) to transmit power from the nacelle (that must follow the wind) to the tower without using slip rings.You would probably want to insulate the motor and power supply from ground to avoid the possibility of welding current passing through bearings and gearbox.awright
Reply:Try to look at the glass half full, Zap lol. Always shooting down good ideas.
Reply:Did a little spreadsheet to calculate the RPM you may want for a rotary welding positioner.  TIG is normally done at about 3 to 6 inches per minute (ipm) surface speed, and MIG may be done at around 30 ipm, so see the attached calc. for RPM depending on the part diameter. Attached FilesRPM per diameter for welding.doc (50.0 KB, 100 views)
Reply:Thanks for all of your helpWe bought one from weld plus.Jeff
Reply:Originally Posted by schiada96Thanks for all of your helpWe bought one from weld plus.Jeff
Reply:Nothing like a purpose built tool !!Anything worth doing is worth doing RIGHTThe best way if you can justify it.What model did you buy and what did it cost?awright
Reply:a common, semi high torque motor often overlooked... a windshild wiper motor.but, day late, and dollar short, looks like the problem was solved.
Reply:slamdvw, I agree about the great potential utility of windshield wiper motors and window winder motors.  In fact, I was searching the All Electronics website for the listing of the automotive worm gearhead motors that I had picked up some time ago, "just in case," when I stumbled across the DCM-315 that I recommended above.  However, I believe that the DCM-315 would be much more suitable than a randomly selected windshield wiper motor for a welding rotator primarily because of the fairly high basic no-load speed of typical WW motors.I was looking at two new automotive WW or window motors from All Electronics in my motor drawer .  Judging from the torn plastic bag with the ALL label, the two were sent under the same catalog number, DCM-61 (but I could be wrong that they both came under that number).  The best and most suitable one runs at 32 RPM at low current (0.9 amp) at 12 volts, no load, and is extremely quiet and smooth.  No mfgr. or part number printed on that one.  This one could probably be throttled down to a useable speed for small workpieces on a directly mounted turntable.The second draws 9 amps at 12 volts, no load, is fairly noisy, and runs at 160 RPM.  This one is clearly not suitable for a directly driven work rotator due to speed.  It gets very flaky if you reduce the voltage enough to get down to even a few RPM, which is still too fast.  Lots of cogging, low torque, and stalls easily requiring higher voltage to get it started again.Each of the automotive motors were about $15 to $17 a year ago (don't remember exactly), but I think the DCM-315 for $79 would be far more suitable for a direct drive turntable for workpieces up to, maybe, 100 pounds.  Of course, the automotive motors would be fine if provided with further speed reduction, but then you are getting into a more complex project, having to provide a pulley and belt or gear arrangement and bearings to support the turntable.I realize this is too late to be of any help to Jeff, but maybe some others out there are interested in building a cheap rotator.awrightLast edited by awright; 06-28-2007 at 02:32 AM.
Reply:awright gave me another idea.  How about a nice big surplus stepper.  Direct drive.  A PIC and a stepper driver would make a perfect controller.Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:I have not built a home brewed rotary welding table, but have worked with many different versions.  Really it should not be a difficult project for many of the clever people on this forum.  I encourage people to go for it!One of the stumbling points to making a welding positioner is how to make the rotating electrical ground connection.  Generally you have a stationary ground cable connected to a "brush" of some type, that rubs on the surface of the rotating shaft (or a bushing on the shaft).  The most expensive rotating ground I've used was a precision mercury filled unit that cost $5000 (what a waste), and worked no differently from a simple home made braided copper strap wrapped around the shaft.If you are going to make your own positioner, don't sweat the rotary ground, try the braided copper strap.Or, simply attach the ground cable to the table, pre-wind the cable opposite of your welding direction, and let it unwind as you weld.  This will work fine, unless you need to make a whole bunch of revolutions in one continuous weld.Keep it simple, Stupid.
Reply:I would really think that any sort of rotating table, even manual powered, would be helpful. I am just thinking about how many times I have had to weld around a pipe or something and had to take more time than the weld itself took just to reposition the part in the vice, or try to prop it up at another angle. Being able to keep the part secure, or even relatively secured, and then move the whole table to make your way around the part (even if it isnt in one continuous weld), would still help. And without all the hassle and worry of making it motorized, this could easily be an afternoon project.
Reply:phila.renewal, while a stepper might be suitable for a welding rotator if driven by a microstepping driver, such a driver is somewhat expensive and surely not easily implemented in a simple PIC project.  Used with a simple phase-switching, full-step driver, virtually all step motors will have a 1.8 degree or larger basic step size which would be too coarse for any but the smallest workpiece.  For example, the tangential step distance for a 3" diameter workpiece on a table driven directly by a common 1.8 degree (200 steps/revolution) motor would be 1/20 inch.This coarseness of motion could be reduced to any desired degree by providing an additional speed reduction stage using gears or belts, but then you loose the simplicity implied in the direct drive you suggest.Another limiting factor in using a direct drive stepper is that, in the absence of a physically or electronically implemented viscous damper, for some polar moment of inertia that could easily be reached with a welding workpiece on a turntable, a stepper will either refuse to step and will just shudder or will step erratically in response to a step command.  This could really mess up a weld bead.Microstepping drivers allow steppers with modest resolution, like the 200 steps/revolution that is most common, to be driven at much smaller steps limited only by the sophistication of the electronic driver but, once again, you lose the simplicity and low cost implied in the directly driven stepper concept.All in all, I do not think a salvaged stepper motor can compete with the simple DC motor and high ratio gearhead as a welding rotator in the absence of a further speed reduction stage or a microstepping driver.awright
Reply:Oh yeah.  I forgot to mention that All Electronics that I linked to in an earlier post has a neat little package consisting of a 1.8 degree stepper motor coupled to an 18:1 triple spur gear reduction box.  For someone wanting a light duty rotator for fairly small loads using a stepper motor, this could be a nice starting point.  No way of knowing an actual load rating, but just looking at the one I picked up several months ago, "just in case...,"  I wouldn't be surprised if it could handle 20 pounds or so if the load was not cantelevered out too far from the gearbox.The downside is that the 3/8" shaft emerges from the gearbox on the same side that the motor is mounted on making mounting of a turntable slightly more difficult but still definitely feasible.  There is also an electric brake that should be removed. Check it out at:http://www.allelectronics.com/cgi-bi...GEARHEAD_.html$15.35.They also offer a sophisticated modular stepper motor driver:http://www.allelectronics.com/cgi-bi...R_DRIVER_.html$45.00but note that it is rated at only 1.5 amps per phase while the motor on the gearbox is rated at 2.2 amps per phase.  I do not know enough about these things to give accurate advice, but I think it would be possible to trick the driver into working with the motor at reduced torque by adjusting the current limit or padding the motor windings up with low value power resistors.  With the 18:1 gearbox, I don't think the loss of torque would be any problem at all.Assuming they would play together nicely, and I think they would, you'd have a neat starter package for a light duty rotator for about $60.  You would have to provide the power supply (they might even offer a suitable one), a turntable, supporting brackets, and a simple variable pulse rate generator.awrightLast edited by awright; 07-01-2007 at 05:40 AM.
Reply:Originally Posted by slamdvwa common, semi high torque motor often overlooked... a windshield wiper motor.but, day late, and dollar short, looks like the problem was solved.
Reply:For manual use what about using an old large bearing? We have some removed from pumps that are about 6the or 8" diameter. I don't know if it would hurt the bearing if you ground to the table but might be worth a try
Reply:You might like to have a look at the positioner I built a while back. The thread includes the woes of looking for a suitable motor.http://weldingweb.com/vbb/showthread.php...ght=positioner
Reply:Mmmm just seen the date of the first post
Reply:Shox Dr, since you've opened up the topic again, I'll add a comment.First, very nice job!  I like the grounding strap scheme.  However - - -I wonder if you've insulated the motor from ground or insulated the turntable shaft from the motor.  If not, welding current will divide up between the motor bearings and the ground strap on the shaft according to the relative instantaneous resistances of the two paths.  Initially the ground strap undoubtedly has lower resistance to ground than the motor assembly, but with a little dirt or corrosion buildup under the ground strap, the current through the bearings could eventually become significant.  Any resulting bearing damage would build up slowly (unless you had a serious, albeit unlikely, failure of the ground strap in which case the damage would immediate) and you might not know it was occurring until serious bearing erosion had occurred over a long period.I would either insulate the turntable from the motor or float the motor from ground and rely on the ground strap as the safety ground path for any motor fault current.  The latter approach undoubtedly violates electrical codes, so research it yourself and use your own judgement.  I am not an electrician. I speak (well, actually write) from the experience of having the bearings of the motor of an expensive front-loading washing machine fail after less than a year of service.  Disassembly revealed absolute proof of bearing erosion due to electrical discharge through the bearings to ground.  The sources in this case were the current spikes through the bearings due to the very fast rise times of the square waves driving the switched-reluctance motor windings from the solid-state motor controller.  The fast rise time driving pulses were coupled from the windings to the rotor and thence to ground via the bearings.  The bearings looked like they had been running in sand.The manufacturer would not acknowledge the engineering problem but offered to send a repairman out to replace the motor at nearly the price of a new machine or to sell me a replacement motor for only 1/2 the price of a new machine.  I opted to buy new bearings for $20 from the local bearing supply house and (after some experimentation involving viewing the current spikes to ground via the motor on an oscilloscope) to lift the ground strap from motor to dryer chassis and use insulated bushings under the motor mounting bolts.  I did make damn sure the dryer chassis was well grounded and hung a large tag on the motor and stuck a label on the back of the machine warning any future repairman that the motor frame was ungrounded.  The dryer has worked flawlessly for about 15 years since then.The safest alternative on your turntable would be to keep the motor grounded and provide an insulated bushing between the grounded turntable shaft and the motor.  It looks like a direct, metal-to-metal connection in the photos.awright
Reply:Check this out...http://www.ebay.com/itm/130594241759...84.m1438.l2649this plus a slow speed motor to get the IPM you need..Classic 1D 200SAE 30086 SA 200Hyperthem 45Jancy Mag Force O/A Victor-GossCable's remote2-12" Mathey Dearman bevelersLN 25Miller Auto Set 211Wendy's Pancake/Jackson PipelinerNew Holland LS 180Great story man....tell it again!
GMT+8, 2026-1-1 06:02 , Processed in 0.117919 second(s), 18 queries .
