Thermal arc scout
发表于 2021-8-31 22:24:22 | 显示全部楼层 |阅读模式
Hi. I'm looking for opinions on the Thermal arc scout compared to the Lincoln outback 185 or miller Bluestar 185 The Thermal arc seems to have a much higher duty cycle But lower generator power Is it an inverter welder?only weighs about 200lbs an only 9hp honda engine are theyChinese origin? I dont think there is much difference pricewise new but the Miller or Lincoln would probably be worth more used?  Any replies or coments welcom;  Thanks;  Josey
Reply:I have used one of these in the past. This is a real Honda DX engine, not a china knock off motor. These are excelent welders and will run 6010 very nicely. Good scratch start tig welder as well. This is an excelent product you will be very happy to own.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I have one also. It's a excellent welder along with a great generator. It starts my 3 hp/ 230 volt well pump real easy.(down 520 ft) I also can run my LN-25 pro with .035 self shielded flux core wire. 6010 is no problem at all. It was made in Italy.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Hi again  Thanks  for your interesting replies and coments  Where Did you buy your welder ? and how much did it cost about ? Thanks  Josey
Reply:Originally Posted by JoseyHi again  Thanks  for your interesting replies and coments  Where Did you buy your welder ? and how much did it cost about ? Thanks  Josey
GMT+8, 2026-1-1 07:48 , Processed in 0.106543 second(s), 18 queries .
