sa 200,won't ramp-up from grinder
发表于 2021-8-31 22:24:21 | 显示全部楼层 |阅读模式
my 55 shorthood ramps-up fine when using welding rod, but it will not reve up when using the outlet plug, any ideas or didn't these older sa,s reve up from the outlet. if i pin it the grinder works fine, but at idel the grinder runs about half speed, any ideas? thanks
Reply:It isn't broken they don't idle up from the 110 outlet.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:...which is why the Idler Instructions http://content.lincolnelectric.com//...im/IM179G1.pdf states to latch the idler in the high idle (welding) position when using the auxiliary power outlet.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I have to pin my shorthood open to make the grinder work to. But when i hook my grinder to my remote box it will hardly turn the disk. Is this cused from a bad connection where i tied the wire on the remote into the wire on the back of my plug on the front of my machine?
GMT+8, 2026-1-1 06:02 , Processed in 0.077439 second(s), 18 queries .
