Air Vantage 500
发表于 2021-8-31 22:24:20 | 显示全部楼层 |阅读模式
Just a note to any of you using one of these in extreme cold--- turn your air cleaner so it doesn't draw outside air when it is very cold. See my other post.
Reply:well i know in alaska when the spec'ed trucks they used to get air cleaners that had a butterfly valve that could be opened to allow the truck to take in the warmer underhood air.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2026-1-1 07:50 , Processed in 0.077674 second(s), 18 queries .
