weldpak 100 problem
发表于 2021-8-31 22:24:20 | 显示全部楼层 |阅读模式
just bought a weldpak 100, this will be my 2nd machine and it will not feed wire. took apart and i am not getting power to the feed motor when the trigger is pulled. if i hook the motor up to 12v, it works fine. guy i bought it from ordered a new circuit board for it and i replaced that and no change. when tracing power backwards, the blue capacitor that powers the motor has no voltage there. any help on what to check? thanks for help
Reply:Does the gas solenoid work when you press the trigger? The most common thing to fail is probably the fan motor. The fan has a 24V transformer wound into it that powers the PC board. Should be wires 214 and 213.
Reply:Here is a diagram Attached Images
Reply:I had this problem with my 175, I wasnt getting power to feeder motor.  Fan would work, solenoid would click, but no wire would feed.  I called a tech for lincoln and he asked me a bunch of questions, he said it sounded like the circuit board. I was about to gonna buy one, but it ended up being the heat control dial (or the dial that sets the amps).  it has 4 different positions and it was not in the detent mark.  I have heard that if the amp out put dial is bad, that it will not feed wire either.  Move the dial switch to a different position, try this and hope it helps.
Reply:solenoid works, fan works, just not getting power to the drive motor. will check the things you guys suggest and will let you know. thanks very muchbill
Reply:Originally Posted by safiresolenoid works, fan works, just not getting power to the drive motor. will check the things you guys suggest and will let you know. thanks very muchbill
GMT+8, 2026-1-1 06:02 , Processed in 0.106678 second(s), 18 queries .
