Rebuilding SA-200-f-163 Questions
发表于 2021-8-31 22:24:19 | 显示全部楼层 |阅读模式
Hi everybodyI have another question out there. Last time I left off late last weekend tour the machine down and took out the main armature. Found out it was bad and found a great parts machine for 300 bucks. So now I'm looking at this project and am like wow I might as well rebuild the engine so I just tour the whole thing down and just started to clean everything. Usally I would have it dipped but to say money will be pressure washing and wire wheeling everything. So now it comes to the questions.A. Were do I find a good quality engine rebuild kit for this maching?B. Is the F-163 engine the same engine as a F-162 and if so or if not, are the rebuild kits interchangable?Thank youP.S. Also in the parts machine had a Radiator that was recently rebuilt. Mine was rotten so the Parts welder has already paid for itself twice.
Reply:Many exceptions, and previous rebuilds, but mostly the 163 has larger bearings than 162, thus making the kits different.Good Luck
Reply:http://www.stumpfweldingsupplies.com/200parts.htmlthey should have the parts you need or know where to get themLocal 597 PipefittersCertified stick and tig pipe welderLincoln Ranger 305g - for saleMiller 185 migMiller Digital Elite
Reply:try moter inc. dont know the link but if you do a web seach youll find thim. youll get a complet kit valves guids springs pistons gaskets everything for under 500.00 shiped to you!can't can't do nothen
Reply:try enginekitsonline.com and then click on the the tractor secton. the have kits for f163 engine cause these engines were also put in in all kinds on tractors and generators. the radiator should fit.
GMT+8, 2026-1-1 06:02 , Processed in 0.101319 second(s), 18 queries .
