Lincoln Super Glaze 5356 Wire
发表于 2021-8-31 22:24:17 | 显示全部楼层 |阅读模式
Has anybody run this wire? Did you notice a difference from the cheaper stuff?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:what do you call the cheaper stuff? if you are talking about the 4043 wire, the difference is strength. the 4043 wire is recomended for most aluminum welding where strength is not vital. the 5356 wire is harder to run and needs to be used in applications such as welding a truckbed or boat.
Reply:I have yet to like Super Glaze of any alloy. It doesn't seem to work that well on my blue machines. It was ok before they went to the SG line, but afterward I was unimpressed.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:Lincolnwelderboy,If it's not SuperGlaze, it's got to be cheaper. I should have specified, my bad.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Joker,Are you wondering about it before you use it, or are you wondering about it because you have used it and are having problems or difficulties or differences?You do have to change the operating parameters a bit compared to 4043 wire, because of the difference in electrical conductivity between 5356 and 4043.  That's for GMAW.  It's about 15-20% WFS difference between the two alloys to get the same amps out (faster for 5356 and slower for 4043).GTAW you just mash the pedal until you get the puddle and then you dab and repeat.    The best laid schemes ... Gang oft agley ...
Reply:I haven't bought it yet. It is more expensive than the off-brand, but the offbrand isn't CHEAP either.My machine won't run those little 1 or 2lb spools. So I have to buy a 16 or 20lb spool. So we are talking about 100bucks. I don't want to spend that much on an offbrand only to find out I should have ponied up for the SuperGlaze.My machine (PowerMig 350MP) has preset programs for different wires. I can fine tune it from there if I want, but it should be pretty much good to go without much fuss. I asked because I do notice a difference between the Lincoln L-56 wire and the off-brands I have tried for steel mig welding. Sorry guys, I will try to be less vague when I ask my next question. That was stupid of me. I know better.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Sorry guys, I will try to be less vague when I ask my next question. That was stupid of me. I know better.
Reply:Jason,Well, you do make an excellent point. Ok. Now to go call and order my wire. None of the LWS here carry it. So I have to pay to have it shipped from Phoenix, AZ.Thanks for the input. Sometimes you know what the right thing to do is, you just need someone to give you a little push to do it.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2026-1-1 06:01 , Processed in 0.072381 second(s), 18 queries .
