A cart for my Maxstar.
发表于 2021-8-31 22:24:14 | 显示全部楼层 |阅读模式
So I got this cart from my brother that he got from a friend for free. I don't have pictures of how it looked when I got it but it's built from a basic dolly and this guy had used all different sorts of scrap materials to make a basic cart that was functional but kind of flimsy.  I could have just reinforced it in places to make it stronger but I wanted to make it my own and do something a little different so here's what I have so far. I built this arm to clamp near the top of the argon bottle rather than using a chain or something to secure it. These are the clamp pieces for the end of the arm. And here it is put together. Sent from my iPhone using Tapatalk
Reply:A couple more pictures that apparently wouldn't fit in my first post. I definitely have more to do and I will post updates as they happen. The next step I think is to come up with a way to stow the leads (hidden when not in use if possible) and stay true to my weird design. Sent from my iPhone using Tapatalk
Reply:Oh and I also want to say that I saw nothing wrong with the original cart being made from scrap pieces. I love finding good steel as scrap and putting it to good use. Pretty much everything I'm using for this cart is scrap/salvage. Sent from my iPhone using Tapatalk
Reply:Interesting to say the least.  It does look cool and unique.  But where do you store tools, consumables, PPE on that cart?  It doesn't look too efficient for portability of your "support" equipment that goes with any welding machine.  Also, how long does that cute bottle last you before you fill 'er up?Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Well as I said I am not finished yet.  You bring up good points and I will consider those as I continue to build.  And I suppose my design may never be very efficient for those things but I think I can find some creative ways to store a few things on it.  I think it has some potential.  If not I'll build another one.  I just got that bottle and have been running mostly stick since but when I do empty it I will replace it with the next size up and it will not be so cute anymore.
Reply:Looks cool. Im completely ok with something looking more cool than it is functional. I would probably not be the guy to build something like that, but as I said... it looks cool. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:A lot of wasted space but I like it. Looking forward to seeing what you do to it. I am not very creative so I like seeing what other people do and learn a little from each.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Creative and stylish.One question/concern, is the Maxstar actually fastened down to the plate?I have a bad habit of moving work around with the ground clamp still attached. It appears a slight tug to the side might topple an expensive machine. FWIW....Hobbyist - At what point is a "hobby" out-of-control?
Reply:Very cool. I like it, that's thinkin outside the box. I see tons of potential with this. Modify as needed and update with lots of pics.Great job man.
Reply:Originally Posted by FORTEALLOYCreative and stylish.One question/concern, is the Maxstar actually fastened down to the plate?I have a bad habit of moving work around with the ground clamp still attached. It appears a slight tug to the side might topple an expensive machine. FWIW....
Reply:Originally Posted by sqznbyVery cool. I like it, that's thinkin outside the box. I see tons of potential with this. Modify as needed and update with lots of pics.Great job man.
Reply:Originally Posted by STEELEforREALIt's not fastened down now but it will be.  That should be my next step.  It would be a sad day if I let that sucker hit the concrete.  Thanks for the feedback!
GMT+8, 2026-1-1 07:49 , Processed in 0.106407 second(s), 18 queries .
