Question???
发表于 2021-8-31 22:24:13 | 显示全部楼层 |阅读模式
Can I run a thermal arc or tweco 252 inverter machine off my miller trailblazer 302?LINCOLN WELDANPOWER AC-225/DC-210/6 CODE #8705MILLER TRAILBLAZER 302 EFIMILLERMATIC 211MILLER BOBCAT 225G
Reply:After looking at the 252 specs. The input amps are 39.5 so yes it should run just fine off a 302. I have a 302 and I run an everlast MTS250S off of it with no problem. To tell you the truth after looking at the Tweco252 it would not surprise me if Everlast makes the 252 for Tweco.  The specs are almost identical and even the case is very close to the same as the MTS250S.Last edited by thegary; 11-05-2015 at 12:05 AM.
Reply:Thanks for the info!LINCOLN WELDANPOWER AC-225/DC-210/6 CODE #8705MILLER TRAILBLAZER 302 EFIMILLERMATIC 211MILLER BOBCAT 225G
GMT+8, 2026-1-1 05:36 , Processed in 0.102527 second(s), 18 queries .
