Can't figure this thing out.starting instructions show 10 pictures on top of machine cover. It shows a plug that is positioned in 240/120v outlet, but has no wires coming out of it, if that makes any sense. The 4 prong plug has a cap over the side that the wires should be coming out of.I'm assuming without this plug connected I will get no power, but I never received this plug with the machine.If there's anyone who is getting what I'm trying to explain, please help. I'm at my wits end.Starting instructions as follows. 1. connect battery.... 2. fill and check engine oil... 3. fill check fuel..... 4. turn on fuel flow..... 5. pull speed lever to run.....6. press heat button if below zero.... 7. turn off circuit breaker... 8. turn key to start position.... 9. insert 4 prong plug...... 10. turn on circuit breaker.
Reply:Attaching a photo of the plug in and the instruction illustration would be helpful.Sounds like the standard garbage instructions.
Reply:Is this it ? http://precisionpowertools.net/details.php?cdid=69
Reply:Nothing in the manual about a plug, that I can find www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's |
