Tig Welding Potmetal
发表于 2021-8-31 22:24:09 | 显示全部楼层 |阅读模式
Can potmetal be tig welded? I am told it is a poor grade of aluminum, is this correct?
Reply:Yes. I use AC when i did.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:It is not impossible...More like improbable......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It's easier to use a solder and flux made for pot metal to do repairs.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:http://en.wikipedia.org/wiki/Pot_metal
Reply:JB weld works great on it.  It's usually not structural stuff.
Reply:I welded a corner joint on a tonneau cover for a friend and it was a disaster. I thought it was aluminum at first, then when I started the arc, it started popping and spitting like i've never seen before. I've never had that much trouble with aluminum before. I got through it, but it looked really bad. Do you think it could have been potmetal?
Reply:There really isnt anything made of pot metal anymore, which is essentially Zinc, or Zinc alloys. Most of what you guys are asking about is low grade aluminum castings, which are hit or miss regarding weldability. Only way to find out is clean 'em up and strike an arc.
Reply:"Pot metal" is a generic term but generally nowadays refers to zinc-aluminum die casting alloys. Many items are made from these alloys, some of which have the strength of mild steel.Welding zinc alloys with any arc process is essentially hopeless due to the low boiling point of zinc. As stated above the best way is solder and flux with a torch.JohnA few weldersA lot of hammersA whole lot of C-clamps
GMT+8, 2026-1-1 06:02 , Processed in 0.102228 second(s), 18 queries .
