查看: 13|回复: 0
Converted Lincoln AC 225 tig setup, arc starter, pedal in IA
发表于 2021-8-31 22:24:06 | 显示全部楼层 |阅读模式
Alright so since I was fortunate enough to win an ebay auction I now have an L-tec Heliarc 307i and my homebrew tig setup is going to a new home to help pay for the new machine.So:Lincoln AC-225, upgraded cooling fans, capacitor/resistor bank to keep excess corona out of the windings, chinese foot pedal, internal electronics to change phase-angle of incoming 220 VAC single phase electricity.  This is the same mod several people have done on the hobart boards.  Probably have over 30-40 hours of tig time on it without incident.I don't have a picture but it looks the same as every other lincoln tombstone except that there are 2 hooks on the front for torch and ground clamp, and theres a wire coming out the back connected to the foot pedal.I also built an arc stabilizer to start tigging without scratching the aluminum.  This is all I used for a couple years to weld canoes at my work.  The arc stabilizer is a separate brown metal box with a knob on it to control intensity.  I'll also throw in a cheap blue cart that I bought to roll everything around on, since I previously also had a chiller setup on this (but keeping it for the new tig machine)I'll include a WP-17 air cooled tig torch and ground clamp.  You'll need to supply your own argon regulator and bottle.Located in Boone, IA but I make frequent drives to the minneapolis-st. paul area if it would save anybody a drive.  I'd rather not ship.$250 OBO.  PM me if you are interested.
Reply:Can't edit this post?  Anyways its sold.
GMT+8, 2026-1-1 06:01 , Processed in 0.098352 second(s), 18 queries .
